Ok, the lowwer A-arms on my new to me '01 9-5 have been subjected to 10+ tears of Northern New england salt and winters. That are pretty good shape but huge flakeds of paint are coming off them same as with the engine block? Block I don't care about, but how should I procede with the lower a-arms?
Wire brush, rustoleum paint. You can probably remove the ball joint and pull the arm down lower with the car off the ground and get almost everything painted. Tape off the surrounding area. They are also easy enough to remove entirely. One bolt in front, two rear, and the ball joint.
Common issue
Is this a common issue with these vehicles?
Banned
My 2000 lpt has 11 Bufflao, NY, winters and looks similar. It looks like it might have been rust proofed at one time. You wouldn't know it but can follow the rust pile on which part of the car I've just worked on. :)
There was a recall announced last year for the control arms that could rusted through. Just inspect them during your oil change.
Recall
This car does not have the latest PCV recall either, guess I could take it there to be checked out for both.
