Status
Not open for further replies.
Well, with the MAF problem basically, a new problem has devoloped. I get a loud whirring sound like what a bad power steering pump would make but it doesn't fluctuate when I turn the steering wheel. It does increase though relative to engine speed and is accompanied by a slight high-pitched whinning sound like that of a bad bearing...maybe the idler pulley? Love this car but the things failing at the 65-75K mile mark is ridiculous! :roll:
As you say its could well be a pulley, mine was a water pump, before that it was the ACC compressor, and you really dont want to know how much the PS pump is :eek:
Lets hope its the idler pulley ;)
How can I properly diagnose if it's the pulley? I guess release tension on the belt and check for play? I just had the water pump replaced. I was looking at the "How To" on here about replacing the idler pulley, how long does that take? Anyone done the shorter belt conversion and is there any advantage?
Closed thread as the question has been asked again by the author
Status
