1 - 2 of 2 Posts
My 1992 900 S has 187k miles.
It has rather loose steering action. The wheel is dead on-centre, after a while you get used to it but for a rather important amount of turning there is no effect at the wheels.
Worn steering rack or something else?
Hi , put the car on ramps. Then have an assistant turn the steering wheel back and forth slightly while you watch from underneth .Watch the inner and outer tie rod ends, and the u-joint to the steering column for looseness. I bet its an outer tie rod end worn out . ;) Pat
1 - 2 of 2 Posts
