1999 9-3 HOT. Generic Bluetooth OBD2 module with the Torque Pro app...
Short term fuel trims are pretty low and behaving like I would expect (low single digits and fluctuating). However, the readings I'm getting for long term fuel trim are 35%...
I have a vague recollection that there is a quirk that makes the Tech2 the only reliable measure of LTFT. Something about the ECU reporting it incorrectly to aftermarket devices.
Anybody know anything about this? Am I crazy? Google and the site's search feature haven't turned up much.
I'm pretty confident I don't have vacuum leaks (I've replaced them all and I have smoke tested the car). I do have a probable leak at my exhaust manifold (two broken studs...will be fixed this weekend) and my O2 sensors are who knows how old. BUT...how can my LTFT be so high when the STFT is normal? If long-term is essentially an average of the short-term, shouldn't it be a lot lower?
I should probably just drive and forget about fancy apps.
