1 - 8 of 8 Posts
Hi, I am having some real problems getting the lock nuts off the top mounting of my rear shocks. The nuts are too thin for me too put two wrenches on. I was thinking of just dremeling the nuts off, I don't care if I damage the shock. Does anybody have any idea on how to get them off?
Does the shaft spin if you try loosening the top nut first?
How about a deep socket?
Do you have a vice-grip needle nose pliers? Use it to hold the bottom nut.
A vice grip is also to wide to hold the bottom nut without also holding the top nut. The shaft does move when I turn the top nut.
Jezzadee said:
Sometimes the only thing that'll do it is an angle grinder.
Yup, five minutes with the grinder will save you a lot of hard work with spanners etc.
Does smell pretty bad as you go through the rubber bush though!
Will third that. Just take grinder to it.
All of my 3 900's have had to have then chopped off. First ones by the garage then the second two by me to save time.
Saab Mad
You can cut off the top rubber bushing to give more space, and then get an open-ended spanner onto the lower nut with ring spanner on top nut. You might find that the shaft turns anyway.
I ended up cutting the shaft (hacksaw :roll: ) as it's quicker and less of a nuisance.
It gets worse though when you have to tackle the shock's lower mounting bolt through the trailing arm.
rear shocks
My rear shocks were dead easy to remove, the top mount was only held in by layers of rust compressed together:eek: .
Welding in new mounts in did take a bit of work though:roll: .
Had to take a grinder to the NS one though.
1 - 8 of 8 Posts
