1 - 12 of 12 Posts
i bought olipressure gauge, T thing that u sscruew in insted ow oilpresure sensor and on this T think u put both sensors.
where is exact location of oilpressure sensor?? maybe picture?
magrahamkp08 said:
where did you get this oil pressure gauge from and do you know what else you will need to install it
this is on my old car http://www.garaget.org/archive/38040/32664/large_32664-387774.jpg
i bougt new from here
http://www.biltema.se/products/product.asp?iSecId=460&iItemId=77421
u connect powerwires to it and one sensor wire.
i bought http://www.biltema.se/Archive/Product_images/32/Large/32-1076_l.jpg
into that u plug 2 sensor but i read that on saab ther is so little space? if so i will use 10cm rubberhydrolik tube.
this is how the sensor look like around 4.5cm diameter 5cm deep
http://www.biltema.se/products/productimage.asp?iItemId=76640
D.M said:
ok thnx will i need to remove starter or can i reach sensor from above?
I don't believe I've ever heard of anybody being able to remove it from above. You would have to have incredibly small hands. It is possible to remove without first removing the starter but it is much easier if you do!
i removed starter and their is no place there maybe 5cm maximum so i have to make a tube with something like a 90d bend.
but so far i done this: moved the volt down and wired oilpressure:
1 - 12 of 12 Posts
