Hi
Where is the ECU located in a ’03 9-3 1,8t Sport Sedan? Someone who has a picture? Is it easy to have a look at without spending to much time with a screwdriver :D.
Hi,
If it's in the same place as on the 1.9TiD then it's behind the wheelarch liner on the passenger front wheel. It's to the front of the wheel, protected by the bumper, but rather exposed to wheel water! You have to take the wheel off, then the wheelarch liner and it should be easy to spot.
Garry
It's probably bolted to the intake manifold under the cover that probably says Saab Turbo on it.
At least that's where it is on mine, and isn't the 1.8L really a low-boost 2.0L Ecotec?
