Does anyone have any suggestions for an alternative to 5057724, its the double sealing washer thing that goes either side of the banjo fitting on the high pressure entry to the rack.
I think (or hope) that is the cause of my leak, its right in that area and after pulling the old seal, its pretty heavily corroded and eaten away in one spot.
Looks like the inside diameter is about 16mm, I was thinking maybe some soft copper crush washers or maybe some of those rubber sealing washers (though I'm not sure if the rubber is up to the high PSI of the system).
Anybody found something that was available locally that worked?
