For a few weeks, the car has been acting up. It has not been wanting to go into 1st or reverse for me. But if I turn it off, and place it in gear, it would start with no problem and shift gears as it should. Until I stop at a light and I have to repeat.
One day, the car got stuck in 2nd gear. Once parked, fortunately in our driveway, it was not in any gear at all. Here is a video of the only action that the shift rod would do. Saab gear shift action
We discovered that the linkage was missing a bolt/screw.
From this link, Gear rod (900NG Parts > Transmission > Transmission & Related > Gear rod) I harvested a diagram of the shifter linkage above. My missing bolt should be threaded through the bushings and into the engine side of the assembly. See the blue arrow?
I can not find specs for this bolt. I need to know exactly what to order. It may be a 9/16ths bolt. It should be under 4 inches in length. Does anyone know exactly what I should purchase?
Currently, the linkage is being held onto the car with a cobbled-together too-long bolt with nuts and washers to shorten it. I need to do better. To be explicitly clear, the bolt I need is neither "screw #4" nor "screw #10" listed on the diagram.
It is still doing the "not been wanting to go into 1st or reverse for me. But if I turn it off, and place it in gear, it would start with no problem and shift gears as it should. Until I stop at a light and I have to repeat."
I have located and ordered a used linkage, I also just received new metal bushings from Maptun parts.
www.maptunparts.com
I will assess the two linkages, and decide which one to have the new bushings put on, then replace.
Here is a picture instructional on how to lock the transmission in the correct gear until the linkage is put back on the car: 25.03.2005: Saab NG900 Shifter Alignment - photo.platonoff.com
Here is a picture instructional on how to rebuild the linkage: 25.03.2005: Saab NG900 Shifter Alignment - photo.platonoff.com
Here is a video of the movement of the linkage prior to putting in the bolt:
Thoughts? Suggestions?
Bushing kit, Shift Linkage, Saab 900/9-3/9-5 -2003
Bushing kit, Shift Linkage, Saab 900/9-3/9-5 -2003 - Following the success of our update kit for model year 2004 and onwards, we have now developed a corresponding product for previous model years as well. With bushings in bearing bronze, this kit is a really good update that improves the feel...
