I just got myself a new 900S project, I have always wanted one of these so am well chuffed! However, the fuel economy at present is shocking at around 20mpg which is far more petrol usage than imagined. I found a leak at the fuel filter which appeared to be the problem so I replaced it but if anything now, it's worse! I replaced the vacuum hose a while back but didn't replace it with a standard part but instead with what I thought would 'do the job', would this have an effect on the fuel economy? I had an emmisions test the other day, all good in fact very low. I have serviced it all within the last two weeks and nothing has changed. Please can someone advise my next move, thanks.
While i'm here, is there a huge difference between the high pressure and low pressure turbo's? Can I switch without to much arsing around or there a different cooler system etc.?
