ignore the "d" in the subject
just had to disconnect the speaker(aftermarket) & forgotten;oops: which is - & + colours are yellow and white..
yellow is live i think, do you have a multimeter?
If you still have the stock connector lying around, on it is marked 1, and 2 - 1 is negative (assuming your connector still has a little bit of wire attached to it, then you can figure out 1=> color)
Sorry I don't know it by color, I have a stock sub instead.
