Those are simple contact points and they look like new. The problem lies with the control circuit. Where is the control circuit you ask??? Keep asking, cause I don't know yet, lol.
As far as both switches being faulty with identical symptoms, not very likely at all.
I took pictures while disasembling to be able to re-assemble it just the way it was. I didn't really took pictures after cleaning but if you insist I can do it but I took a bowl, put about an inch of isopropyl alcohol, soaked it, wiped it with paper towels put it back together. Problems kept happening therefore I got another one from scrap yard, and again it took it apart cleaned it with isopropyl alcohol, put it together replaced in car. Exactly the same symptoms, sometimes works fine, sometimes sluggish, sometimes it is switched to left and it changes right mirror.
The best way to make sure you have clean contacts, is to take the part to a sandblasting cabinet and hit it hard. Off course there might not be anything left over at the end, but at least it was clean for a few seconds 😜
Guys it is cheaper to get another one, in winter they go for like £2000-2500 in very good state than keep putting new parts into one that doesn't even have a fuel lines
I took photos to have proof that i blasted it today with sandpaper cos I know no one will believe me I will update in few days.
Those contacts are good to go. If it still has the same issues, then another area needs to be looked at. I imagine the electronics are on the other side of the PCB? Have you looked at the other side of the board? Maybe there's something going on there? How much could there be? A motor, the switches, and a few bits for memory and speed control. Not much to these things.
Ok I wasn't precise enough, the removed fuel lines going around tank to fuel filter. So parts of fuel lines are gone and fuel filter is gone. Those are removed.
Yeah I will look through everything if I won't manage to find any fault I will get new switch but that's why I'm thinking about removing whole doors and checking there, I suspect use of that magic tape that they used to fix all other electronics. I thought I am newbie at car repair but even I know you don't use masking tape to fix electric cables or to attach grille....
If you still have them apart, I would use 0000 steel wool. Probably called something else in Britain, but you probably know what I'm talking about. Lightly go over the brass areas until they shine. We wanna make sure all the gremlins are out.
I try to do small things after work ( like cleaning mirror switch for the 574 th time ) but when i have half a day off like today I try to do something slighlty bigger, especially that this Sunday we are doing full service on my mate's wife car so I won't do much on saab if anything. So I applied autoglym care balm to seats, no pictures taken as it doesnt improve massively their look on first day but rather when it's fully sink in and protects them from UV and damage. But I also regenerated Lights.
This is how they looked initially
I can't be sure yet but I might get half a day tomorrow. If I'm lucky, I will finally remove the battery and try to open gearbox oil. If I succeed I will order oil, I need 2.4 litre if I'm correct?
Also there seems to be some noise when I'm shifting gears from 1 2 and 3. It is rather random, sometimes it happens and sometimes it doesn't, its when i release the clutch, it's like a fart at the back of the car (I know such a great description ) any ideas ? 1st gear is sticky, and now this noise appears more and more often, kind of like farty misfire, I am starting to suspect clutch, but usually it can be heard at front and usually when hitting 2nd gear revs will got through the roof and I get none of that. What can it be?
OK I'm getting desperate it is FM55 101 gearbox and I can't find fill plug. I even recorded a video. Every photo/video I've seen had it right under battery tray, this one seems different. Anyone can see it?
