141 - 146 of 146 Posts
uhm.... All the pictures went away and now the guide is useless. Someone make a new one? :-(
jack up car, un do the drain plug, then the oil filter, let it all drip out, lube up the rubber seal on the new filter screw it on, screw in the oil plug with a washer fill 4- 4.25 liters of oil and you are done.
I meant more like where that screw was etc. Once I got under the car it was easier to find than I had expected. That being said the nut is stripped to all hell and im a bit SOL now
