I have looked at the car and the problem is indeed the caliper. I can't turn the wheel at all by hand with it jacked up
. Parking brake cable seems fine.
I am going to do brakes all around while I'm at it. I have ordered rebuilt rear calipers for both sides, new hoses for the rear calipers, new rotors for the front (Zimmerman Coated), banjo bolt washers, new master cylinder cap as mine is a bit suspect.
I decided to go with all Akebono pads front and rear. I have had Centric ceramics in the back with were pretty good and also good on the dust issue. The fronts have always bothered me with the dust as they must be semi metallic but have decent amount of material left. At this point since I have so much to do I figure it is time to just go for it. It would be nice to go for 314's in the front but not right now. I put low miles on the car so these should last for quite a number of years.
Car will have to sit until all the parts arrive from three different vendors - RockAuto, RMeuropean and thesaabsite. Just going to have a bit of a commuting problem for a week or so.
Thanks for all the suggestions;ol;.
