1 year I joined this site, first time posting :cheesy:
so this summer I've changed all the lights on MY07 to leds cause they look awsome :D. I've read that I need resistors so I got them all installed myself and they look great, no error messages on the SID so no hyperflashing. but there is a problem, my lights flashes all the time (not bright like when you actually turn them on, but flashes quickly at about 3 seconds interval each time). Which basically means that when I drive on the road, my turn signal will flash dimly. I finally had time to take a short video, first showing normal hazard lights flashing (no hyperflash proof), then when car is shut down. All this for you experts to help me analyse my problem :p
Reminder, all the resistors are in place...
video link:
Hi... Check out this old post. It has some good information about using 12V resistors, not sure which ones you might have. If you seen this link previously...sorry! http://www.saabcentral.com/forums/showthread.php?t=167350 I have LED bulbs to light my rear license plate and have the same strobing, but for about 5-7 seconds after the car is off. So not much to annoy or worry myself about. Good luck!
I've seen a million threads about this, but I don't think I've seen a single example of someone who personally wired resistors in and was able to eliminate the strobing. It has always been hearsay.
Edit:after looking at 20 threads I was finally able to find one person who personally got them to work, but he didn't elaborate on the type of resistors or anything. There are also a ton of people concerned about the heat that the resistors generate around plastic. Here is that post http://www.saabcentral.com/forums/showpost.php?p=1458652&postcount=10.
I would recommend just getting regular bulbs that are super white, like these www.racinglab.com/polm4supwhit.html. Good luck with the stobing, I hope you figure it out.
Thanks a lot for the replies, I looked through them but I guess no one actually know how to solve this. I will just keep the strobe effects as it's only the turn signals that does it when i'm driving. I guess it can only be considered as added safety measures for night time driving :roll:
Or impersonating a construction vehicle lol. There is no way I would keep them on my car if they did that. I think the LED section of Hidplanet.com would be able to help you, and steer you into doing LED's properly.
I wouldn't be surprised if you get pulled over for that.
Also, I don't want to jinx you, but it might be hard explaining the situation if you were to have an accident where someone runs into you thinking that you were indicating.
