Hey everyone. I installed led fog lights with Sylvania load resistors and they still blink after installation. What did I do wrong. How do I stop the blinking when shut off?
You need relays. Or wire in bulbs somewhere in wiring to give it a load for bulb check.
Definitely your own decision to put LEDs in fog lights - I personally never would because all they do is blind other drivers and scatter light every which way - a lose-lose for everybody.
If you must though, you'll need to wire in a 5-pin relay AND add a resistor or keep the factory bulbs in circuit. The relay keeps it from strobing and the resistor or stock bulb keeps the SID quiet.
You need incandescent lamps, they do not blink.
