1 - 20 of 49 Posts
So I searched around the forum and everything and I can't really find my answer..what type of LED should you use to replace the stock city lights with? I know the bulb number is 194 but there are several different styles of LED's and I wasn't sure if one was better than the other. Is there a certain amount of wattage I'm supposed to be focusing on? Also, if someone could post some links to some good places to buy these at it would be appreciated! Thanks
When my city lights went out I replaced them with PIAA W5W platinum super white. I paid $13 for the pair. I’ve read that the LED city lights can look too bright, so I went with these. These bulbs aren’t overly bright at all. They have a very slight shade of blue, but the light isn’t distracting. These city lights are rated at 3800k. Although I’m happy with the look of these city lights, the PIAA Xtreme whites may have a slightly less blue color as they are rated at 4150k.
Or you can go the easy route and just disconnect your working city light. My friend disconnected his city lights and it actually looks pretty good. When my city lights burn out again I am just going to disconnect them.
W5W or 194 is the bulb. or wedge.
and i find it kind of unbeliveable that you didn't find anything b/c there are several different threads about.
as for where to buy them, google it.
prepare for them to strobe or flicker once you put them in.
I got some 5w online. Blue something? I can't remember the name. They look blue but have nice white light. Since they are tiny they don't reflect the blue color in the housing like I was afraid they would do. Remember, actual led lights will flicker because of the bulb check when the car is turned off. You can test and fit different resistors to get rid of that but not sure if anyone actually got that to work yet.
Discussion Starter · #11 ·
I think I'm going to get some of the Polarg M4's. I don't really feel like dealing with resistors and the m4's have a nice look to them. I'll post before and after pics after I put them in
So you put in the Load equalizers and there fine..... It's the OP's choice.
Did you put them in your car? From what I remember people never found what value was actually needed to stop the blinking. Or maybe people really just didn't try.
Discussion Starter · #15 ·
So I just put the M4 bulbs in and here's pictures to show the difference between them and the halogens. The bulbs appear less blue in person but you can still see the difference here..
Before:
After:
With all my lights on (6000k low beams and fogs):
I just removed mine.
exactly what i did....headlight looks so much better without the city lights; the crips blue color of the HIDs fills in the headlight and looks niceeeeeeeeeee!!! :cheesy:
On the other hand ... still looks good PhilC
1 - 20 of 49 Posts
