I am replacing several light bulbs and brakelight switch for my 97 900 - brake lights, turn signals...
Nothing wrong but I think it's safe to replace them before they fail while the car is on the road.
I find this spec is useful to find all the replacement bulbs spec on the one page.
Lamp Replacement Guide from Sylvania for '97 900.
http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/AutoLRG-Results.htm
1997 SAAB 900
High & low beam headlamp
9003/HB2
9003SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9003ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9003XV XtraVision Halogen - The Brighter Light
9003CB Cool Blue Halogen - The Whiter Light
Parking light
1157A
1157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1157ALL Long Life Upgrade: Up to twice the life of the standard lamp
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
1157A
2825
Rear turn signal
1157A
Tail light
5007
5007LL Long Life Upgrade: Up to twice the life of the standard lamp
7528
7528LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
7528
High mount stop light
2825
Fog/Driving light
H3-55W
H3ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
License plate
6418
6418LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
7506
7506LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
2825
Rear sidemarker
7528
Ash tray
2721
Glove box
6418
Dome light
6411
Step/Courtesy light
2825
6418
Trunk/Cargo area
6411
Instrument-general
2721
Check engine indicator
2721
Hi-beam indicator
2721
Seat belt indicator
2721
Brake warning
2721
Automatic transmission indicator
2721
Directional signal indicator
2721
Just watch out for the 90/100 W 9004 headlight bulb that some have tried. Too much "W" which heats and ruins the wire insulation and connectors...
These numbers agree with the owners manual (11 years old) but updated..
Probably good to run off a copy...
Just remember that Saab vehicles are sold globally and North American catalogues aren’t the same across the pond, nor are the bulb numbers. This is a current bulb listing from the European GE website. These bulbs are available in North America for purchase also, but cost twice as much as their equivalent North American counterpart. Considering that our cars originated from the EU, I’d recommend using the bulb table below.
This table sounds more accurate. Thanks!
no pain no $train...
i bought some new brake lights to replace the passenger side bulb and discovered it was not in fact the bulb which was broken... i can't afford to run the codes through a computer, and there are no warning lights or messages associated with the problem so maybe the comp. would have nothing to find anyway? what could be causing this problem??
Use your test light to check the current flow to that spot; if no glow, then back track, but examine the contacts carefully - these can be bent a little much....
Did you use your meter on the bulb ?
7528 is now specified, but the original was a 1157 which replaced the old 1034. There are very slight differences.
