i need new suspension and i need it bad. but i cannot afford tires, koni suspension, springs, and brakes all at the same time. I do plat to lower it, that is why i want the koni FSD, will it be good on stock springs? i suppose yes but i just want to be sure. also i have stock 17's x 7.5 wheels. what is a good spacer to use to get that flush look? 25mm all around?
I'm curious as well, I've got the same set-up as you, and I want to essentially do the same. Except I was looking at changing out the stock springs for something else.
im reading a lot that koni fsd arent supposed to be paired with aftermarket springs. neither are the bilstein HD. but the sport series of either company arent very comfortable.
any input? i do not like the fact that the car does not sit level.
