1 - 15 of 15 Posts
Hello,
I changed my cim module for a new one and now I want to program the module, but when I insert the key it tells me that the key is not acceped...
ISM is brand new
Whats the problem ??
You Ecm has to be programmed to the new icm
So...you pull up 4 year old threads to reprimand someone and now you're just spewing incorrect info. Off to a great start. (y)
Diggs this thread is less than 7hrs old..
ISM doesn't need programming to anything the,cim on the other hand does..Been a while but can old fobs be programmed to new cim..
What should I do, I want to program my new CIM, but unable to turn the key to on. I try to put my old ism and not work key not accepted again..
Help !!
talking about the one i closed.
Help !!
What key? Old keys can't be used on new CIM.
Discussion Starter #10
New CIM, old key yes. I have 2 keys but same things happen with sid said key not accepted... I can not program cim because i have tu put key to the on position before add security acces
Brand new CIM will accept old keys.
You need to have all keys, TECH2 and security access.
You can force key to move with TECH2.
Discussion Starter #12 (Edited)
I have tech 2, all keys, and security access.
How I can force tech 2 to turn the key ??
My battery car is falling flat is it possible that it no longer recognizes the keys I only want to program the cim. Can I remove the keys with the tech and maybe start over?
If i order brand new key did you think i will able to program new cim. The only thing that blocks me is that I am unable to turn the key to on to do the programming
Recharge/replace battery first. After that we can continue.
Discussion Starter #14
Same thing happen with another battery.
If i hold 3 spring on the switch it suppose to turn or not ? (check picture ?)
Yes.
Those are contact points to PCB.
1 - 15 of 15 Posts
