Hi - The plastic part that allows you to hook your key to a keychain has cracked off of my key for my 2007 9-7x. I've been carrying around a loose key in my coat pocket for about 2 weeks now, I've tried super gluing, tying ribbon around it to keep a key ring on, everything. Is there any sort of silicone skin or holder available to put over the key fob itself? Thanks!
No, replacing the whole key will be VERY expensive…
I don't think I've ever seen any type of silicone cover or other that would eliminate your problem either…
If you still have the piece that broke off, a good 2-part epoxy glue will work much better than any super glue will… I always use this for plastic parts, making sure to rough up both surfaces with coarse sandpaper and clean well with rubbing alcohol before gluing…
Good luck! ;)
