blows fuse 29 whenever it feels like it usually every couple of hours. gives a rear light failure on the display. replaced the rear light panel still does it regaurdless of weather. Car is 00 vert. any suggestions?
Welcome to SaabCentral, Badcoupe
If the '00 is the same as the '96, check the trailer connection end someplace in the trunk(boot)..
Then go to Harbor Freight and see if they still have the short detecting device...if necessary.
Exactly which rear light is not functioning ?
Thanks for the welcome. pulled it in the shop tonight and found that one of the two wires in lic. plate light strip was shorted out to the body. repaired shrinkwrapped and done. load indicatyed that the circuit was pulling almost 8 amps constantly. after repair it was just under 2 amps like fuse 30.
