1 - 8 of 8 Posts
'02 9-5 Aero Wagon, '88 SPG, '02 Viggen Vert, '01 Viggen 4dr, +Triumphs & MGs
You actually should be fine....but as the craigs post has expired can't tell what you would be getting...you can check genuine saab for how to install their kit. http://www.genuinesaab.com/psi/files3/T793openAirInstall.pdf
Overall it is a fun change to the car - you get to hear a lot more of the turbo spool. Personally I went to a dry filter over the K&N oiled...but the theory is the same.
The K&N can let some oil particles onto the MAF and confuse it eventually. If you do it with the oil based filter, just clean your MAF regularly.
And yeah, the whine can be cool. I have that on my T5.
If you have a T5 (1999)...
Get a 3" air intake hose from a auto parts store. Something like this: http://www.ebay.com/bhp/air-intake-hose
Get a 3" plastic plumbing or electrical pipe "end" adapter that the hose will fit on. You may need a thin gasket if the hose is too big. Something like this but in 3" size. Look for a nut or female piece that fits the threaded side: http://guide.alibaba.com/shop/male-adapter-2-1-2-in-conduit-pvc-5140109_32054370.html. Home depot/Lowes is a good place to try different adapters and find one to fit your air hose.
Cut the snout off your airbox. Cut the hole large enough to fit the threaded end of the adapter in. Screw it in, or if you have a giant nut, use that to mount it. Install. Hook up the air pipe and run it down behind the headlight. No lower.
Get a K&N filter. Install in airbox.
Done
Done
Thanks. I only have owned this car for a few days and im already love this thing.
Sent from my SM-N920T using Tapatalk
just leave it alone ; K&N clog fast you get worse fuel mileage and no power increase, in fact as they clog they get less power. Hydrolock easy
stock is best.
sad for all the whiners and woosh/fsssst wannabes
1 - 8 of 8 Posts
