1 - 7 of 7 Posts
I installed a K&N air intake, since then after riding a while the check engine light appear and then when i stop and start back on first, the car move very slow up to the second gear. Someone help me please.
The airflow is improper, K&N's have near Zero success rate on most 93 SS's. There's a dozen or more threads, even K&N admits it. Here is a cut and paste from an old thread:
....over a year ago I contacted K&N and posted the response, it seems even there application guide, which no-one ever reads it seems, states that the 57i is not compatible with all 93's....I'll do a quick look to see if I can find it, but just a quick one....
Here, this was quite a hot topic for a while.
From Nick Peres at K&N:
"This particular intake kit was found not to properly fit/work on the models that are not listed in our application guide. Hope this helps,
Tech support"
well the thing i dont understand is i really checked product for my 9-3 specifically... if you do a search by car model you will find that one for it. Is it possible to reprogram the computer or something to make it work.
You could probably use some of the components it came with. . Check out the DIY thread and rig up something. It's not a complete waste. .
1 - 7 of 7 Posts
