I just completed replacement of the turbo. I did prime the turbo before starting. After reconnecting the ignition cassettes and replacing the fuel pump fuse, I started up the motor. It turns over and starts up very quickly... then immediately shuts down. I could only keep it running by pressing the gas pedal hard... but its erratic rpm swings led to shutdown anyway. It will not maintain an idle. I suspect from reading other posts that this may be bypass valve issue or a boost controller issue. Can anyone help me diagnose the problem? Thx!
