1 - 20 of 33 Posts
:) just ordered a Hid kit from xenonlink.com 149.00 5000k 3200lumins, brightest on the market, also it has the high beam built it :) here is the link
Yeah, let us know. I'm not in the market for them at the moment but everytime I look at how yellow my headlights are, I cringe. I think a nice shade of green would match the c0ckpit :)
Might I suggest you buy new lenses as well?
otherwise, all your light is scattered about and in no particular direction.
Hey guys, somewhat off topic sorry. What is the brightist regular bulb we can get for our cars I have a hi beam out.
Warumono said:
Does a company make new lenses?
Genuinesaab.com makes ecode lenses that arent dot legal but w.e they look much nicer
Tyler
Becarefull with the install, there is a 99 Viggen (currently the motor is toast) that had a hid kit hacked in and the car couldn't pass inspection.
since you on about lenses i thought the hid kit was ok to fit with the standard lenses but i have herd you need the clear lenses (like on the newer 9-3's and that) is this true??? also does the new shape 9-3 lenses fit on the 1998 modles ????
brightest temp?
brightest lumens?
or highest wattage?
If the bulbs are direct-fit(pop in place of an h4 bulb) and made to "duplicate" the pattern of an H4, you should be fine. Although, an old, pitted glass lens will destroy the beam/light pattern.
G96nt said:
brightest temp?
brightest lumens?
or highest wattage?
o i thought u ment you would need new lenses as i am looking into getting a hid kit (6000k-8000k) for under £100 delivered wooooo.
but would the clear lenses off the newer 9-3s fir a '89 9-3 ???
I would guess not.
It sounds like that kit uses "HID" H4 bulbs in place of your halogen H4's,
so there's no need to change them, though.
Discussion Starter · #15 ·
yea there both new headlights anyway due to an accident in mcdonalds drivethrough, and the bulbs are direct replacement for the 9003-h4 bulbs, thats why i got them, it would be cool if they even made cleare lens id be in heven
i know the clear headlights look alot better thats why i was asking would be intresting to find out if we could get any to fit our cars
I bought these and installed them in my Viggen last week. It is literally a plug and play kit, installation is as easy as changing a regular bulb would be. The HID low beams are phenomenal, even with stock lenses the dispersion is still fine. However the "high beams" suck major *****, they are worse than the stock low beams were, and are less bright than the HID low beams! E-code lenses might help the high beams, but I think I am going to add some auxiliary driving lights on a seperate switch instead...
ParaMedic_Saab said:
I have the Osram +95 or something like that. They have been the brightest and whitest bulb I have ever used. I have tried the Silvania ultrastart or whatever. They were good, but these have been the best.
http://store.candlepower.com/bconibr90ulh2.html
The main difference I see with this bulb, is the distance the light travels, quite impressive.
Do you have any pics, Im probably going to order these.
1 - 20 of 33 Posts
