Hi all... it's been a good 5 years I guess since I've been on this forum; back then it was for a 9000, now I found a pretty cherry 900 'vert and have been having a swell time with the top down.
Except...
The A/C doesn't blow cold. I jumped the low pressure switch and the compressor works, the A/C switch works, everything seems just peachy.
Except...
Once I found out it had low refrigerant, I bought some of the cheap DIY R12a stuff and have been screwing around ever since. I replaced the original R134a adaptor (it's been converted from R12 at some point in the past) with the one from the R12a kit. I ran the compressor, added in the PAG equivalent stuff (since I figure who knows how long the compressor's been out of it), it was accepted into the system and everything hovered at around 15psi. I ran the engine for about 5 minutes or so, then went about adding in the epoxy-type sealant, figuring that if the leak was still in there I should do something about it. The sealant went in fine too, and the pressure stabilized at about 30psi.
Except...
Once I took the filling hose off, the bloody oil and sealant started spewing out the low pressure side! There was much cursing, smoke, and oily mess which required a garbage bag full of paper towels to clean up.
Anyways, what gives? It's the Seiko Senki compressor. All the electrics work like a hot damn. The compressor works, and while I left the hose attached (prior to the spew) I actually felt cold air coming from the vents! One weird thing was that the compressor did cycle off a few times while I still had the hose attached; during these cycles I saw the low side pressure spike to around 80psi, then once the compressor spun up again it was back down to 30.
And before anybody gets started, yes, I know this is the chintzy way to go about getting this issue resolved. I know I should replace the receiver/dryer, I know I should get the system professionally evacuated, but I want to go into any shop work knowing as much as I can about what I need done, and this spewing issue is beyond my understanding.
Any ideas would be greatly, greatly appreciated. I can't name my grandson after you, but I can put in a good word. Thanks!
Except...
Except...
Except...
