is this the clutch?
689 10
it feels like the clutch on my 92 900 doesn't ever let go. I can get into gear fine, but any slightly quick acceleration causes the rpms to go up for a second or so before you feel/see the speed increase.
is this the clutch going bad? from what I've read, it sounds different than most clutch issues.
1 - 11 of 11 Posts
· Registered
So my Bentley manual says that I need a spacer ring (Saab tool no. 87 91 618) and a lever arm (Saab tool no. 83 94 033).
Is there a way to do this with less specific tools? OR does anyone one know of anywhere in the Chicago area where I could borrow or even rent these tools?
· Registered
You can easily make your own ring tool out of a piece of 1/8" square steel stock.
It's cost you about $3 at OSH or Home Depot.
It'll be nearly indestructible, and you can re-use it several times if you need to.
The one at eeuroparts.com for $10 is very flimsy.
The one I made myself is much less of a struggle to use.
· Registered
Discussion Starter · #10 ·
Did it! Took most of the day but it's done.
Thanks for the input. The old unit was a pain in the butt to remove. I just couldn't get the fingers depressed far enough.
It drives like a new car.
The square steel stock worked great. Thanks for the tip!
1 - 11 of 11 Posts
