1 - 7 of 7 Posts
· Registered
Hi Guys
How's everyone going? Hope you're all well.
My car, I believe, needs a new fuel accumulator and I've found this item on eBay. It's described as a fuel level sender Saab Part #9361965
Apparently it's for C900's made after 1983 (mine is actually a 1983 model)
Is a fuel level sender the same as a fuel accumulator?
If it is, will this one work on a 1983 car or not?
Many thanks
Rosie & Ruby
· Registered
Thanks
Hi Lloyd
How goes it? My car's fuel gauge never registers as being completely full (even though the tank is brimming. The best I ever get is 3/4 full according to the gauge. Would this fuel level thingy solve that problem?
Rosie
· Registered
Saabina - hope that all is well.
Lloyd is correct -- that is a fuel level transmitter.
The fuel guage issue can be lots of things, including the transmitter. Kinda trial and error to find the problem, I think.
Don't spend too much on this! A spankin' new one is just $50 (US) or so.
Take care (we still want pics!!)
· Registered
Trust me its not the accumulator!
Hello again Fellow SAABer's ,
It sounds to me as though u really just need a " new fuel sender unit" not a fuel pressure accumulator which holds fuel pressure under rest pressure for restarting. Which would result in hard or no start under a variety of conditions.:D hope this helps!
BTW Rock on c900s!! oh BTW the pic is of the fuel sender which is the part u need to replace or check out!!
· Banned
IF your Fuel gauge .. works.. Ie it goes up when you fill the tank and goes down when you drive.. even tho not giving a full reading when you know there tank is actually full. THEN it's not yer Sender .. the thing inna Photo (although these ARE rebuildable.. if one was of a mind to :)
You merely have to tighten the Grounding Nuts on the rear of the Dash Gauge..(Saabs are seriously affected with Ground issues :) accessed (with significant difficulty tho) thru the Speaker hole. Persevere it IS possible.. barely.
Usually these need only an 1/8 turn or so.. this Works. as advertised.
1 - 7 of 7 Posts
