Matthew said:
The reason is that the inertia of the heavy flywheel smooths out the engine's inherent roughness (all four-pot engines would be the same) and improves drivability.
Tomarse said:
I'm assuming that it is the same as any other 'performance' modification. saab presumably built their engine whilst striking a balance between cost and performance, and bearing things like the fuel consumption in mind.
So that website is lying when it says there are no drawbacks from the mod and that Saab fitted an unnecessarily heavy flywheel?
Tomarse said:
...if youre actually sitting there designing an engine then there are easier ways to gain power than fitting a different flywheel.
On the contrary. It sounds an incredibly easy way to gain power. Far easier than playing around with turbo compressor maps. They wouldn't need an aluminium one, they could just lighten the original steel one.
Don't get me wrong, I'm not trying to knock the idea of them. Indeed I'm all for cool mods which enhance the car. I can understand why car makers don't fit expensive and complex fuel injection systems, kevlar brakes etc., but in the case of a flywheel it is so simple (and cheaper) to put one of optimum size on that I'm thinking there has to be a good reason. When I made my 1% comment I was not saying its
only 1%, rather that 1% is an awful lot for no benefit.
It seems to me, as you guys pointed out, the engine will not be as smooth and the decresed 'spin down' time necessitates quicker gear changes to put less wear on the clutch. Also I'm wondering if the heavy flywheel is to limit the forces put on other components. The stress on the timing gear will be far greater in an engine which spins up and down faster for example. Think diesel engine cambelts at the smoke test.
In a race engine yeah, its great and if thats what you guys want your cars for then fine. But I want a car that is good as an all rounder and doesn't need rebuilding every 20,000 miles. I guess I just need a little more convincing before I go out and spend so much money on one.
