1 - 14 of 14 Posts
I am experiencing an intermittent loss of heat from the center dash vents in my 2009 SC. Side vents still moving warm air.
Thoughts on a cause? I would think if the heater core is going I would not be getting heat at all.
i assume ur coolant level is ok, and the car reaches normal operating temp within reasonable time, no check engine light for thermostat code?
if thats all true, then u have a mixer door issue ..
Remember that right part of center vent is right temp and left part is from left temp.
Coolant and temp all ok, no codes etc
any guidance on resources to trouble-shoot a mixer-door?
I assume u dont have access to tech2..
Lets try smthn, with the engine running, press both the RECIRC and AUTO buttons for few seconds until u hear the motors inside the dash start moving , then try the heat and report back
1 - 14 of 14 Posts
