is the error code the same as originally mentioned 12223?
Yes, with a but. After changing out the intake bushings the light came on for a moment and never came back on during a 30-45 minute drive. The hesitation occurs consistently under hard acceleration at about 3700 rpm. I don’t try to push past the hesitation by keeping the pedal down. The hesitation. Seems to be unrelated, certainly to the CEL.is the error code the same as originally mentioned 12223?
Not input, but a request: can anyone direct me to a source for above-mentioned 'input bushings'? Sounds like a good idea for any high-mileage 900. I recall replacing the throttle shafts & bushings on the SU carbs that were on my old Volvo 144 sedan. It was the best thing I ever did on that car! It idled like a rock afterwards.The other good thing I did was to rip out that rotten 35- Amp Bosch generator and replace it with a 65A Delco alternator!Yes, with a but. After changing out the intake bushings the light came on for a moment and never came back on during a 30-45 minute drive. The hesitation occurs consistently under hard acceleration at about 3700 rpm. I don’t try to push past the hesitation by keeping the pedal down. The hesitation. Seems to be unrelated, certainly to the CEL.
This should be what you're looking for: SAAB Intake Manifold Bushing 7515208 - Proparts 61345208 | eEuroparts.com®Not input, but a request: can anyone direct me to a source for above-mentioned 'input bushings'? Sounds like a good idea for any high-mileage 900. I recall replacing the throttle shafts & bushings on the SU carbs that were on my old Volvo 144 sedan. It was the best thing I ever did on that car! It idled like a rock afterwards.The other good thing I did was to rip out that rotten 35- Amp Bosch generator and replace it with a 65A Delco alternator!
I purchased mine from Eeuroparts. Rubber grommets, not the parts your talking about. Responded too quickly.Thanks for that suggestion. What I'm actually trying to locate is a set of two bronze bushings for the throttle shaft and I guess, a new throttle shaft. Any assistance appreciated.
Sounds like something any decent machine shop could handle. You could probably purchase a bronze bushing that is close and have it modified. I've done that for other parts.Thanks for that suggestion. What I'm actually trying to locate is a set of two bronze bushings for the throttle shaft and I guess, a new throttle shaft. Any assistance appreciated.
Even less to an LH 2.4.2 Yeah, that makes sense. Thank you.If they're really worn (rare), get another throttle body.
These cars don't have constant-velocity carburetors, so they're not terribly sensitive to tiny vacuum leaks before the metering piston/needle. It matters a little to K-Jet, very little to LH.
Prove it to yourself by putting tiny O-rings on the shaft; they'll last a while.
Dealerships don't do "machine" or "resurface", here in Sodom & Gomorra. They roll with "Sell 'em new"! Thank you.Call a shop or a dealer. Those guys get their work done somewhere.
I have never seen a c900 throttle body leak in a measurable way, and I have pressure tested many .
I plugged the line to the vacuum module on the distributor (intake side) and road tested. Unfortunately the hesitation still occurred. It's an engine so the problem has to be air, fuel or spark related. The fact that it happens with consistency and under specific conditions should help with the diagnosis (I think). If it only happens at high boost, unplugging the APC valve limit the boost to baseline, ~5psi. If the engine does not hesitate under lower boost, could that eliminate spark as an issue? Don't know if I mentionet yet but the engine pulls smoothly all the way to 5k rpm minus the slight dip in power at 3700 rpm.This is a long shot, but I had an '87 SPG that had a very pronounced hesitation under boost that turned out to be the vacuum module on the distributor misbehaving. I can't say precisely what the issue was - I assume the actual mechanical plate binding or something - but replacing the module fixed the issue. You could plug or clamp the vacuum line and go for a drive or maybe use a pressure pump and a timing light to see if yours works right.
Makes sense. As I recall the "resistance" of air is about 10K ohms per inch. I thought it decreased as pressure was reduced, but it's been a couple decades since I took physics.Not really, because spark plugs have a hard time when cylinder pressures are high. By limiting cylinder pressures you've made their job easier.
But, the fact that it clears up makes me think it's not spark anyway. A flat spot at a specific point makes me think timing or mixture.
