I've been chasing an intermittent CEL for about a year (or 1,000 miles) with no success. On several occasions I have retrieved code 12223. According to Bentley the code indicates "Air-fuel mixture too lean" and recommends tightening boot clamps, checking injector o-rings, and the ELCD valve. It also references another code and the oxygen sensor.
The CEL will turn on and off during a single drive and I don't see a pattern. Sometimes the light turns on immediately. Sometimes it turns on after 20 minutes. It turns on at idle, while cruising and under boost. I have not noticed any symptoms, just the CEL. I took some O2 sensor readings thinking it might be the issue or trying to rule it out. Voltage bounced between .100V and .600V with very brief dips to .011V. When I pulled the PCV breather nipple out of the valve cover the voltage dropped to around .100V with more frequent dips to 0.011V range. When I stuffed a rag in the air intake (I tihnk this is what the webpage told me to do to create a rich fuel condition) the voltage climbed to a range of 0.600V to 0.800V. Do all of these readings sound normal? I get the feeling I have a small air leak somewhere and not a O2 sensor issue. Just looking for some ideas here.
