First off the victim is a 91 900S (sorta...) It has the original LH2.4.2 ecu and EZK ignition w/hall sensor on the crank. This is mated to a '92 turbo engine--together they have run very well for the last 22,000 miles giving me an average of 29mpg. Being a hybrid ain't the problem...
OK, best as I can describe it: driving along fat, dumb, and happy the engine suddenly and abruptly quits--as if turned off. NO check eng. lite comes on when this stall occurs. It happened once 2 weeks ago on the way to work (50 miles each way) ten minutes later it restarted. Last week it happened again only after restarting it (and it restarts easily WHEN it restarts) it would only go a few miles before stalling again. Naturally now that its towed back to my garage I can't find anything wrong
The check eng. codes are as follows: 12222/ 12112/ 12252 nothing that would indicate a serious problem. Fuel System test went as should--everything checked ok except the AIC didn't cycle on/off
Can someone tell me what 12414 is supposed to test--it's not listed in the Bently test cycle. The other surprise was 12415 turning my fan on and cycling my A/C clutch--this test was also not listed in the Bently...
Aside from telling me to drive the car till it stalls again and then see what's not working correctly is there anything else I can do. I'm not looking forwad to leaving the car idle in the driveway till it dies so I can try and find whats wrong but I guess I may have to--hate to waste the gas...
Anybody with a similar tale and what was replaced that fixed it?
