I seem to be surrounded by a chorus of various unwanted noises - where are the main culprits and how can they be shut up! I'm pretty sure the area where the rear seat back latches on to the bodywork is one of them ( as with most hatchbacks)
Where can you get such tape?aurelio said:If you are inclined to take care of those noises, there is a product called BSR tape.
It's Ultra High Molecular Weight Polyethylene in tape form. So you may see it labeled as UHM or UHMW tape.
To use, you put a layer of it between surfaces that rub or hit against each other.
It works really well.
While you are at it, you can also use this tape around the house. I used it to fix a dresser with stubborn drawers.
-arr
earthworm said:I just use silicone spray on the rubber seals every 6 to 12 months..I have no squeaks, rattles, vibrations..I can even drive with the hatch not locked(just closed) and nothing rattles unless I hit a spped bump at 60 mph...:cheesy: .
The old VW Golf had a horrible temperature and RPM dependent vibration that I finally cured with Great Stuff expanding foam. But I sold this car; we will never know if the "repair" was permanent...The body metal is too thin in many cars, this is a problem unless all else is perfect..
