I have a 1999 9-5 which I am trying to bring back to life. what parts from a 9000 can I use? or more specifically, are turbos the same? (I was gunna replace my garrett with a td-04) while i'm at it is the 9000 areo ecu compatable with my non areo 9-5? and the heater blower motor wouldnt happen to be the same would it? thanks!
Yes, the turbos are the same on the *AERO's*. In fact, I believe the hot side on the 9000 Aero is actually slightly larger. Not sure about the heater blower motor though.
I thought the turbos were mounted backwards on the 9000.
You can use the bottom end of the engine, but will need to retain your 9-5 head. A few people here have done the swap... it seems straightforward enough.
The T5 cams also give a good performance boost at high RPMs when tuned.
The turbo is the same but the mounting flange is orientated in a different direction. No you can't use a 9000 Aero ecu in a 9-5, they have different Trionic engine management systems.
I believe you can still use a 9000 turbo in the 9-5, you just have to re-clock it so it goes in the opposite direction.
