1 - 2 of 2 Posts
Finally finishing up my head gasket project and because it has been about 3 months in between disassembly and reassembly I've forgotten what screws into the 4 holes on the driver side of the manifold. Step 23 in the WIS says to connect the grounding points and shows 3 holes. There are only 2 grounding straps correct and the go in the middle? What goes on the far right. The far left is the bracket that holds all of the plugs I'm assuming? Also, I didn't use soap when installing the camshaft cover. Does anyone know the point of using soap? I just spread Loctite 518 under the new seal and torqued it per the instructions.
Thanks
Discussion Starter #2
I think I got it, the fourth hole isn’t even threaded. So 2 grounding straps and the cable duct only.
1 - 2 of 2 Posts
