1 - 2 of 2 Posts
The intake manifold had oil on the bottom which dripped on the exhaust. Could not find the leak until I loosened the 2 bolts of the oil filler neck. It was loose enough in the main tube that I was able to move it around. I surmized this was the cause of blow-by. Replacing "O" ring on filler neck with a larger size eliminated this problem.
Yes, I ran into this same problem in my '01 Aero. I wrapped it with some teflon tape to make a good seal until I could locate a slightly larger O ring. I think it might have shrank or flattened out since I did the PCV upgrade because I didn't remember it being loose then.
1 - 2 of 2 Posts
