Thanks all, I'll be pulling it into the garage this weekend and will provide a code.Brian, we describe all those lights on the dash as being lit up like a Christmas tree. Really need a code. It can be anything from the ABS controller going bad to a cracked reluctor ring on one of the axels
Do these symptoms actually set something readable by an OBD2? I thought the OBD2 could only read ECU codes....or with an OBD2 scanner. Important is the error code, not the text the scanner gives out.
But will a standard obd2 reader read these sorts of codes?TECH2 will read all via OBD port.
They are not easy to find and quite expensive. You can get a Chinese knock off but they are difficult to use. Cheapest bet is to pay a mechanic who has one to read the codes for you.Whoops, okay...seems like I have to get a Tech2-thingy too.
To be pedantic, the Innova should provide live data quite nicely, though not those other module codes. My 2011 "deluxe" Innova certainly does live data in addition to ODB codes, in addition to clearing ODB codes. It's a little less successful at the latter, sometimes requiring multiple tries. However, my NG9-3 sometimes goes into limp mode with codes for accelerator potentiometer disagreement. I pull out the Innova, clear the codes, and car runs fine again. The car is REALLY slow and hard to drive when in limp mode for this particular code, and my only other choice would be to pop the hood and disconnect the battery.I have an Innova obd2 tool with the srs, abs, live data ect features. No dice reading anything other than general obd codes on saab. T2 is definitely needed for all around troubleshooting
