could someone give a link for some performance injectors for a 99 9-5 wagon if i were to get a stage 3 ecu along with the fuel regulator. i see they have injectors for 9-3 models but not 9-5.
If you are currently running the red injectors then you dont need to change them till you hit about 280-300 bhp ;)
i kno because i kno ill eventually be up in the 300 area soon and was wondering if there ws a link too some good injectors. i kno genuinesaab.com has green ones for the 9-3 but i didnt see any for the 9-5.
You should follow the advice of your tuner (changing them without the correct software would be a very bad idea) - but its most likely green giants I guess same as on the 9-3 that you've seen :confused:
i've got a stage 4 99 (originally an lpt, now it has a td-04). the stock injectors are fine. dont let anyone tell you otherwise. and trust me, the car moves ;)
