I have some bosch (red) injectors from a 03/99 Saab 9-5 turbo auto.
The injector ID number is 0-280-155-749 which I read are the 350CC injectors.
Will these fit directly into my 91 9000 turbo?
Think the answer is no, the design is diffrent, 9-5 are short n fatter than the 9000. The 9-5 has an additional intermediate plate between the head & the plenium chamber that houses the injectors held higher up out of the port flow
You could try & retro fit this to the 9000 but it would be wise to include the 9 - 5 head to match the change in port design, or get the 9000 head ported to match. A set of greens will end up being cheaper
Set of four Bosch -968 fuel injectors, commonly known as 'Green Giants', for use in high output tuned turbo applications.
Capacity: 465ml at 3.8bar.
These are the most common upgrade above the std 9000 injector, if your heading over 300 crank bhp
I,ve recenty fitted a set & they,ve helped to smooth out the delivery & holf onto the power up the rpm, work in progress
Missed your original point
If you want 350cc then you need the std injectors from a 9000 234R turbo engine - Aero
Ref: the red ones out of the Aero are:
Bosch 0 280 150 431 358.9cc per minute (34.15 lbs/hour, Est HP 71.78 ) @ 3 bar
blue top ones out of the 9K Carly
Bosch 0 280 155 009 346.3cc per minute (32.09 lbs/hour, Est HP 69.26) @ 3 bar
If youe need a set i,ve got spare - contact [email protected]
cheers
