All,
Thought I had fixed the electrical/charging issue... but this morning my gf reported that her car would not start. When she turned the key "nothing happened"
I'm already at work, but I had her check some things:
-battery voltage (taken at battery with multimeter) = 12.5V (battery is only a couple days old btw). VERY COLD in Chicago though.
-when she turns the ignition switch to Accessory, nothing happened
-when she turns the ignition switch to On, nothing happened (no dash lights or anything!)
-when she turns the ignition switch to Start, nothing happened (no clicks, no solenoid, nothing)
Thinking this sounds like a failed ignition switch, I asked her to jiggle the key around to see if we could get a connection of some kind. She did this and said she could get the radio to sometimes come on.
Additional background... we've been having alternator issues that *I thought* were resolved... She's driven the car only a couple times since then.
I had her check the Ignition fuse... it's good. Changed out the Ignition Lock Relay for a spare, no change.
Is there anything else it could be *besides* the ignition switch?
