ok, i'm going to try to describe my problem as best i can. basically, when i take the key out, the ignition locks up and will not turn over immediately. i can jiggle the key and get it going, but obviously i have to fix it.
basically, the ignition comes up when i take the key out. i have to get the ignition back level before it will turn.
any ideas? the key seems fine...
j
[email protected]
Please reiterate. I guess you have having trouble using the ignition key.
Are you using a new or an old key ?
I had some trouble with my spare key(seldom used). I had to jiggle it and use some lock-ease lubricant...Now I just use the old key
Try using a one-two punch of lock cleaner and Lock-ease.
I do not think this is a good place for the ignition lock - in the aspect that liquids(CocaCola) ,dirt, and debris easy fall into the lock. The location is very convenient, no doubt, but the lock is so exposed to the elements that just fall in, molecule by molecule....
But I have never had any trouble with any Saab ignition lock, but I did with the old Mercedes - the cleaning took about 20-25 minutes..
