Ignition cyl disassembly/clean/rebuild info needed.
My ignition got a little tight the last couple days. Figured I needed to lube it as usual. Yada, yada, didn't get to it. But, it really tightened up today... then it locked tight when I went to start the car. As I'd just come out of WallyMart, I headed back in and bought a car of WD-40 to flush and lube it emergency style. Didn't help at all... then all of a sudden it started working fine. FWIW, I have no reverse lock mechanism at all in my short shifter setup so that was not the issue.
I think it might had had a stuck pin that freed up. But, I'm a bit worried that it might have a bent pin. I want to get in there and clean it out properly as well as look for something amiss.
SO, brings me to question: What do I need to know to disassemble it and avoid parts springing all over the place? I know how to remove it from the shifter, but I've never gone past that point to pull the center unit out of the shell. Will the pins & springs all stay in place if I keep a key in there while pulling it apart?
