Got my replacement Amp1 yesterday and put it in today. Nothing has changed! Is there something special to do after i put it in? I was told I didn't have to have it programed with a Tech2. Is that correct? How can I check to make sure I got a good replacement Amp1? I am going nuts trying to figure this out.
Any help would be great!
Test the optical loop for integrity using Tech2 tool. Then verify the optical connectors of the sound system component where the test says it's interrupted at. Or you can tackle one at a time... I experienced a disconnect at Amp2 in the trunk.
Some people have had luck just swapping AMP1. Others have needed to divorce/re-marry the unit with a Tech2. Technically, the unit needs to be added to the bus with a Tech2. The "marrying" procedure links the electronics module to your car's VIN.
