Hi,
I have a question out of curiosity. For nearly as long as I've had my C900 Vert, It's stalled when idling during hot weather. I usually have to foot-feed the idle or just restart often after coming to a stop.
Years ago, a shop moved the Idle Control Valve slightly away from the engine.
I recently had all tubes replaced with Silicone, and the shop removed the spacers I had installed on the IDC. Sure enough, the last few 90+ degree days, she stalled predictable.
I reinstalled spacers (a mere ~1/4") and yesterday, pushing 100, she ran perfectly again.
Question is, why?
I'd have to guess heat expansion is causing the piston to bind in the valve body. Have you cleaned out the valve?
Yes, probably within a year, and in the past too. Giving it some space is tried and true.
Expansion makes sense, I might squirt some lube in, but then again, unless it starts stalling now, I'll probably leave it.
Thanks
Definitely not normal behavior. It's 100F+ for weeks on end here and I've never experienced that on a c900. I would suspect another issue - actual marginal AIC, bad MAF, maybe O2 sensor, vacuum leaks, etc.
There was a Service Bulletin about removing them from the clamp for some year/model. I forget which ones, and why.
Discussion Starter #6
Oh, that's interesting. So the shop from long ago had some guidance, not just happenstance. I recall they did know exactly what the problem was when I brought it in.
I'd love to see the SB... It doesn't take much separation from the block to resolve it.
