I just cleaned my throttle plate and intake body yesterday and something strange has happened.
when i rev the engine above 1500rpm and the revs drop, the rpms stop at 1200 and then slow climb down to 950 rpms.
I have seen my brothers Honda do this so i though fine, its an improvment because before when i boosted and then came out of gear and coasted my 900 i could almost stall it and have done so before but now when i coast the engine speed stays at 1200 rpms and does not go back down to 900 rpms as it did before until the car has stopped moving? it never did this before:roll:
So i decided to clean the AIC, automatic idle control valve and it was dirty with oil, so i blasted it was brake cleaner and polished the body of it, it is from the Lucas system.
So i put it back on the car and now my idle is 1000 rpms i cant get it to go below that even when its really warm.
What did i do wrong? everything was fine before? should i oil the AIC as i put it back in bone dry.
I have to edit this, its 4.55 am and i have just taken the AIC out and opened it all up and gave it a proper clean this time and the little tip seems to be jammed?
i could'nt move it in or out? i even tried 2 volts 4 volts going up in 2 volts steps and nothing! i only got resistance in the first 2 pin holes of 57 ohms, i close the pipes and hooked it up to see if the wiring would move the plunger and nothing? should it be fully closed when the engine is runing and open when there is some load on the engine like from the alternator?
Is this normal for the plunger to be open all the time and not fully close the hole?
