1 - 11 of 11 Posts
Came home to a strange hissing sound coming from the engine. No noticeable power loss. Did some looking around and found the broken hose. I just don't know what the hose is called. I'm guessing something to do with the turbo or the emissions control. I snapped a couple pictures.
Thanks.
Yup, as he said, it's a vacuum line for the brake booster.
The little circular shaped plastic bit is the check valve - this particular part was subject to a replacement campaign a few years ago due to the heat of the engine causing it to go brittle.
The replacement inlcuded a new valve and hose, which was repositioned slightly.
Looks like yours may not have been done at that time (about 4 or 5 years ago IIRC).
didn't think that one was part of the recall,thought it was the one that ran across the bulkhead & above the turbo..
So I guess you guys are saying my guesses are way off :D. Thanks for the fast responses! Now to find the part at a decent price....
the pipe that is broken goes from the vacuum pump to the intake manifold,wasn't part of the recall..
You can find a standard Dorman check valve at most auto parts stores...it looks really cheap compared to the stock, but it works. I threw the Dorman in until I was able to source a stock one.
You don't happen to have a part number do you? Amazon.com has several different check valves by Dorman and i want to get the right one.
Discussion Starter · #11 ·
So the check valve just "slides" into the rigid hose? I was under the impression that the check valve and hose was all one assembly.
1 - 11 of 11 Posts
