So my ignorant self from 6 months ago didn't know there was a difference between the orange and green coolants. So I topped off the coolant in my 2005 9-3 with green. Seeing as it was November in Minnesota, I had no issues with cooling.
Fast forward 6 months, It is now April and my car has been having issues where the engine will abruptly die (always while stopped in traffic or idling) and it wont turn back on. When I turn the key all the electronics come on but nothing happens when i try to start the engine.
The quick fix is disconnecting and reconnecting the battery. Then the car will start and I can usually drive for 2-3 minutes before it happens again. This will continue until I can get the car home. Then I let it sit and the next day it seems to be fine. Also turning on the defroster at full blast seems to help slow the symptoms.
Now I know what you're thinking- Crank position sensor. Replaced it, problems came back.
A couple other pieces of info:
-Every time the problem has come up has been when I have the top down. I think that may just have to do with the fact that it happens on warmer days when one would want to have the top down.
-This doesn't happen every day. I make my commute to work every day just fine(mostly interstate)
-Occasionally when I start the car it will be in Limp mode-disconnecting the battery fixes this.
I fear that as we get deeper into summer the problems will just get worse. Did all of this arise from mixing the coolants? I plan to flush the system this weekend, should this fix the problem? Is it possible that due to a messed up cooling system the new CPS went bad as well?
