After taking the advice of some people on here, I began replacing my timing chain in a 15F windchilll. That was mistake number one.
Mistake number two, one of the plastic straps that I used to connect the old chain broke right at the crankshaft sprocket. The chain fell clear out of the sprocket.
Has anybody been able to recover the chain from above or should I just begin dismatling my engine and timing cover? Also, if the timing cover has to be removed, what is the procedure?
I believe our member 900t has recovered his chain from below the crank sprocket. I think he employed a combination of fiddling, swearing, and fishing with a wire coat hanger or similar. Drinking helps too in this instance. IIRC, 900t's efforts were successful on the chain, but the engine he repaired turned out to be buggered anyway. Tant pis pour lui. I'd try a magnet on a stick, a long piece of wire, and shine a good strong light down there so you can see what you're doing. Maybe it'd help to get a friend to turn the crank at the same time too.
Taking the timing cover is a bit of a difficult dance without taking the engine out. It's best done on a headless engine, but there's a stud (yes, a stud) that connects timing cover to gearbox that you have to remove with vise grips or two nuts locked together in order to remove the timing cover. Also requires oil pump, crank pulley, and water pump removal. Difficult. The reason I say take the head off is because the head gasket seals the timing cover to the head, and this joint will no doubt leak afterwards, because you can't avoid nicking the gasket when pulling the cover.
I'd try fishing first. If you want to dismantle all the way, then buy a proper endless chain and sell your split-link one. Also check your guides, because you can replace them while you're in there.
Can't believe how much trouble I am having with my cars... I am about to purchase another car, a SPG which will need its clutches replaced. I gotta do the chain tomorrow otherwise I'm in very deep guano.;oops:
But I have to admit- your camshaft removal method worked like a charm...All I had to do is just loosen the bolts until all the valves are closed!
Yes I did have this issue. The chain I had attached but it broke and I ended up with no chain inside the engine.
The coat hanger is too thick, wire too thin... I tried magnets on a stick and all kinds of things.
What I ended up being able to do was to use a toilet auger thing (like a large metal spring) and push that on one side of the crank sprocket and get the chain that I had dangled in the other way with a wire loop on the end, then pull it up and around. However you need to be careful not to get it caught up in the upper timing chain guide which is a pain. At the store with the toilet auger, they had mislablled the price and consequently I got it for free!
With the head in place it would be more difficult, but I don't see why it would be necessarily impossible.
It would be tricky though to try and turn the engine without contacting the valves, but if you move the engine slowly a bit, then move the cams, then move the crank, cams, etc and then set everything to TDC once the chain is in place... or even use a kind of flat piece of metal to allow you to pull the chain around the sprocket without turning the crank... though actually removing the cams would be WAY easier and faster.
The engine ran fine after this, the problem was for some reason it lost oil pressure and got seized... I eventually "unstucked" the engine using a really long pipe and a breaker bar on the crank pulley, although by that time I had already installed a used engine. In retrospect I should have done that with the engine in situ (though there isn't really enough space) and seen how the engine ran, maybe it would be beat up around the crank, a little noisy maybe, but hey if it pushes the car past 100 mph and burns less than 1 quart of oil in 500 miles I'm happy...
So yeah, I recommend a 30-pack (I love America) of cheap American beer, a length of thin steel wire and a toilet auger with that spring on the end:
Image uploading. Refresh page to view
If you shine a light in there can you see the end of the chain?
All the valves are closed, yes. I can see the sprocket, too.
There is no chain in the engine right now. I repeat, no chain. I work at a whole metal shop with a lot of tools, so maybe I'll be able to create something similar.
Maybe my 2 years of working as a blacksmith will come in handy now....
OK, lets say that I manage to get the chain through. Lets say I join the two ends together. Then how do I distribute the slack properly? I found a good way to lock the flywheel tightly. The thing is, I removed the plastic clutch cover and I can see something that resembles a mark on the metal bellhousing at the 12 o clock position. I am assuming that this is where I have to align the "0" mark.
I will take pictures tomorrow so we can put this in the FAQ as I think right now I am battling a near-worst case timing chain replacement scenario.
I used those plastic zipties and it decided to break....spawn of satan!
Don't ever use these for this job!!!!!!!!:evil:
Yeah I had always used wire before and it is better... make sure you have the tie-wraps removed and no pieces in there.
The slack distribution is easy, you make it as tight as you can on the exhaust side and between the cams, since the tensioner moves on the intake side. If there is slack on the exhaust side, then when you put in the tensioner, the cams will rotate and retard the timing. You just pull the chain over one sprocket and get it taut, then put the other, you might need to rotate the cams forward or backward a tooth to get them in the right spot... you want everything lining up when the tensioner is installed.
The line on the clutch cover should meet the 0 mark on the flywheel, I think the one on the bedplate is there too, if in doubt, just lay the plastic over the clutch and see if they line up.
I will be attempting this tomorrow. I still can't believe this has happened.
This Coloradian weather is very inappropriate for working on your saab under a tree.
I was able to recover the chain after multiple mistakes and I timed it according to the bellhousing mark. Well, now the car will start to fire and everything, but it is misfiring completely and can barely idle.
I need to know; which mark do I use- the plastic cover one or the notch on the bellhousing? It has all reached a boiling point and I don't think I'll ever attempt to work on anything on the car again.
If I don't fix this immediately, I will lose the car.
When your timing your camshafts you want the 0 mark on the flywheel to line up with the straight mark on the top of the plastic bellhousing. Be very precise on the marks for the cams, if they are not spot on you could be off a tooth, which sounds like what may be your problem.
It's not a real big deal to go back and re-set all the timing marks.
I am pretty sure the repair shop will re-time the engine.
I can't believe this! I've overhauled the entire suspension, interior, and many other wear items on the engine. Now the timing chain has stopped me in my tracks. I am a very poor mechanic.;oops:
Cheer up.
Everybody mistimes their engine the first time unless they're lucky. Well, lots of people do. In the two years I've been here, I've seen at least 4 threads about it. That's not counting all the people who mistimed their engines and didn't write about it. This means nothing about your other skills. It's called a learning curve. Try again. As White says, it's easy to retime. Pistons won't have hit valves if you were close, which you were if it runs at all.
As a mechanic, having a hot head and giving up never pays off. Be patient. Be mature. Remember the thing you're working on doesn't have feelings, so you shouldn't either. In other words, to best repair the machine, you must understand the machine. To understand a machine, you must temporarily become a machine.
thank you for the encouragement. And what you said about "becoming a machine" is extremely appropriate. That'd be a great slogan.
See I'm a man of arts, not bolts and ratchets. Regardless, I have to get this thing done. I want a comfortably functioning Saab that doesn't sound like it's going to explode when you're driving.
I will attempt to retime this beast tomorrow. I took a lot of pictures, too.
It certainly is harder than I thought.
What a test for patience. I thought the patience I acquired while flying planes would qualify me for repairing cars. Wrong, I was.
But as you noted, the car has no feelings. I shouldn't be making this such a complex situation , but frankly tomorrow I'll be missing school. Even though this whole thing has been a big mess, and I have another car which I have to buy and fix for my father (who managed to recover the lost chain in 2 minutes), I can see that there is at least a reason for doing all this. Hopefully someone benefits from this...I hope we can make the FAQ so someone avoids my mistakes....
This kind of patience is different from patience with a system or with other people. And though you're working on a machine, it's not really patience with a machine either. It's patience with yourself, my son. Most people avoid doing things that require this at all costs.
Timing my engine stressed me out SO much when I did my first head gasket earlier this year on my 9000 Aero... I took a whole afternoon to do it... rotated the engine manually over and over until I was sure I had it right... when I fired it up, it barely ran and I was sure I had screwed it up, but after a half hour of idling it was fine... then, about a month later, I was helping a buddy do the head gasket on his '90 C900 'vert, and I forgot to torque the head bolts down properly, and was trying to time the engine without the head toruqed down to the right place! I was so frustrated and worried something was terribly broken... then I finally remembered, after over a day of trying... argh, I didn't torque the head bolts! After that it timed quite easily... but it's easy to make lots of little mistakes like this which turn into huge problems when you're first starting out attempting significant engine work by yourself!
I still can't time it right. Now it wont even fire. I used the flywheel mark and one the first rotation it lines up perfectly with the cam marks, but on the second the cam marks are 180 deg off. I don't get it. Also, I think I messed up the distributor drive...how do you synchronize it with the cams?
The repair shop wants 280 f*****g dollars to retime the engine. I told them to piss off.
The tensioner and guide doesn't tension the chain properly so I extended it two notches to tighten the chain. Chain was perfectly tight between all the sprockets. After one rotation, the cams were aligned but the flywheel was a couple of inches ahead. What the hell? It cranks and backfires a little but doesn't fire. Also, the tensioner is puking oil like crazy...I think a lost a quart of oil while cranking....
The crankshaft sprocket seems to be rotating in front of the cams...Yet there is no visible play in the chain. I don't get this. I must have removed the Valve cover 3 times today.
I need someone from my area who's done this before to help me out. I'll pay if I have to.
Anyone who lives near Denver Colorado and has replaced a four cylinder saab's timing chain let me know immediately.
I can honestly say that I'll never tamper with any part of the valve timing system on a car EVER AGAIN!
Are you timing the engine after tightening the cam bolts down? If so, you've probably bent the valves. Having the cams 180º out is pretty far, so that's the only thing I can think of that would cause that. The thing has to be lined up when the cams are all in place. A way to tell if you've severely bent valves is see if all your lifters come up to the same height when the valves close.
Tensioners often stick when you first install them. They are fed with pressurized oil, so you need to make sure all your seals are there. There's an O-ring on the bolt that tensions the chain, and a sealing-ring between tensioner and head.
I'd help out if I was nearby, but unfortunately I'm not. Here's my method for timing the engine:
NOTE: rotate crankshaft at top of flywheel from intake side to exhaust side as looking from the top of the engine
1: with car in neutral, remove valve covers and remove cams (sorry if you've done it once already, but you should do it again anyways); this requires removing the cam sprockets prior to removing the cams; remove the timing tensioner (old style) or remove the 12mm nut from the end of the tensionser (new style); for later style, use a screwdriver to relieve the tensioner; if you don't understand this, just remove the tensioner entirely and then it will be obvious what I mean
2: remove the spark plugs
3: insert a plastic straw (like from a McDonalds drink) into the number 1 spark plug hole and note it's height; don't drop the straw into the cylinder head (perhaps you could tie a large knot in one end to make it larger than the sparkplug hole)
4: while having a friend hold onto the timing chain and allowing it to roll on the crankshaft, rotate the crank with the flywheel until you see the straw move all the way up and then start to go back into the cylinder; move the crank back and forth until you have determined the peak of the stroke and leave it there (TDC); keep in mind that your helper MUST keep the timing chain tight and feed chain into the crank sprocket while also recovering chain from the opposite side so that the timing chain does not get damaged while you rotate the crank; if this makes no sense, I'll clarify at your request
5: Install the camshafts with the timing mark as close to the proper location as possible so as not to damage the valves.
6: install the exhaust cam sprocket while pulling on the timing chain; it should be absolutely as tight as you can possibly make it; it should also be done without disturbing the crankshaft position (straw indicator) and maintaining the camshaft alignment with the timing mark
7: install the intake cam sprocket with no slack between it and the exhaust cam sprocket while not disturbing the position of the crankshaft (straw indicator), exhaust timing location; it should also properly align with the intake cam timing mark.
8: install the tensioner; later style should not have 12mm nut installed when installing tensioner and ratcheting tenshioner end should be retracted; after tension is installed in head, install 12mm bolt on later style to apply tension; early style just turns in and applys tension with oil pressure.
9: rotate crankshaft/camshaft to verify that the timing marks on the camshafts align when the straw indicator is at the peak (or as close as possible) of it's stroke; be sure that both cams are aligning with the timing marks; remove tensioner and retime if you are off by a tooth
10: once satisfied that the timing is properly aligning after rotating crankshaft several times, install sparkplug in cylinder 1, torque cam bolts to spec, then install vavle cover.
11: start engine and check distributor timing with timing light
There is enough difference between one tooth and another than you should be able to determine if you are timed properly. If you are off one tooth, the straw indicator will be lower one way or the other. Properly timed, the cam marks should line up pretty well whether you are a little before or a little after TDC on the crankshaft. As you move the crank a little back and forth, the straw should bounce up and down a little while the cam timing is pretty much right on the tick. If the straw is going down any significant amount, you are off by a tooth and need to correct it. The timing chain should always be tight on the exhaust side when installing the sprockets, then the tensioner takes up the slack on the intake side.
Euromobile, I can assure you that I haven't bent any valves as the engine's resistance whenever I turned the flywheel by hand wasn't excessive. Of course, we'll know when I manage to fire up the engine...How do you know if a valve is bent anyway?;oops:
Mmoe, I did exactly the same as you have said in your post; I've tried it two days in a row. I am outside, in the cold, and have limited tools.
The starter sounds a little strange but there are no noises of valve to piston impact.
This is my procedure: find the zero mark on the flywheel scale, align it with the block. Lock the flywheel tightly. Then, fine tune the chain and cams, removing all slack between all sprockets. THERE IS NO SLACK AT THIS POINT.
I then turn the engine over until the camshaft marks align at cylinder one TDC.
Then I look at the flywheel and to my surprise it has passed the "0" mark by at least 2 inches. The cams are still at TDC....
What everyone here is talking about is different from what's happening to me.
I just don't get it. Thanks for trying to help mmoe....
The only thing I can think of is that I always turned the flywheel back to the timing mark every time I tried to align it. I am going to try one more time just rotating it one way.
Anyway, I need some info on the distributor drive....I am not sure the dist timing is right either...The little plastic joint that connects it to the exhaust cam broke in two and then I glued it back successfully, but the circular ring around the distributor shaft inside the head is lost. Is this a vital part? Looks like its made out of bakelite/ resin.
Stop using the flywheel timing marks and do it exactly as I said with the straw. I suspect you are rotating the crank while trying to take the slack out. With the straw, you'll be able to visually check that piston 1 is at TDC while you get the cam sprockets on. Also, remember that it is critical to do the exhaust side first since there should be no slack on that side.
The little black ring is the o-ring, but it sounds as if it's hardened considerably. Just go to Napa or where ever and pick up a new o-ring.
The piston DOES move and if you used the straw you would see every detail of how it is moving while you perform the work. I think it is difficult to know if you have moved the crankshaft inadvertently using the flywheel to determine TDC. You also must turn the engine over several times by hand to verify that the timing is in fact correct. This tensions the chain fully and allows you to figure out how many teeth you are off.
If you rotate the engine and find the exhaust cam is not all the way to the timing mark, then you know you need to move the sprocket by at least a tooth toward the exhaust side of the head. Mark the chain and the sprocket with a sharpie so you know how far you have moved the sprocket, then rotate the engine again to verify the timing. If you're still short of the timing mark, move it another tooth. Once you have the exhaust side timed properly, fix the intake side making sure the chain is tight between the 2. Rotate the engine and verify that both cams are lining up with the timing marks.
forgive me if this sounds stupid, but are you turning the engine with the chain tensioner in and the chain tight? from what it sounds like, you are timing the engine correctly but it is when the chain tensioner is not 'engaged' correctly, or there is slack in the chasn on the exhaust side under the sprocket.
remember, inlet side is where the tensioner is so all of the slack in the chain must be on that side, the rest has to be tight.
once again, forgive me if this sounds stupid, or if you have already checked this.
sometimes even the biggest problems are caused my the simplest of things.
EDIT: is there a spring behind the 12mm nut in your tensioner? and can you please post some photos of the engine in its current state, especially around the tensioner area.
So the tensioner is properly functioning, and the last time I did this, there was NO slack anywhere in the chain.
The tensioner didn't operate properly the first time, but then I gave it another notch of tensioning and that solved the problem.
I will be trying again tomorrow, this time I will turn the flywheel only one way, because so far I've been turning it past the mark and then pushing it back.
A friend will help me out with some testing equipment for spark and compression.
Well I finally got it so the timing always stays the same regardless of how much you turn the flywheel (before the marks would get unsynchronized on the 1st rotation).
However, due to stress and fatigue, I mistimed the intake camshaft by one tooth. It cranks fast, backfires now and then, but won't catch. I also checked the cam followers to make sure they are at the same height and they were. So I'm assuming I haven't bent a valve yet.
It's been such a drag and the worst part is that the car is located in a neighboring city at a workshop. I have to travel 25 minutes just to get to it.
I also checked spark and it arcs in white color so no problems there.
It has to start this time...if it doesn't, then I am permanently fooked.;oops:
Related Threads
SaabCentral Forums
3M posts
119.1K members
Since 2001
